For some reason my thread below is locked so I will continue it here. I checked my harness under the dash where the after market alarm was once connected everything I repaired a few years ago is fine. I have continuity from the horn button to the relay socket. I tried putting ground to each of the pins at the connector for the clock spring the horn did not fire. I'm now lost, help.
Horn relay not pulling in Previous thread locked - Potacka11:54:54 08/04/17
